Date/Time: Wed, 15 Jan 2025 09:41:32 +0000
Last price of a developing bar
View Count: 700
[2017-06-15 21:01:18]
rhovega - Posts: 279
I need to reference the last price of a developing bar using ACSIL.
For example, I would have expected the following code to plot a square when the last price of a closed bar is equal to the prior bar's high:
if (sc.Close[sc.Index] == sc.High[sc.Index-1] && sc.GetBarHasClosedStatus(sc.UpdateStartIndex) == BHCS_BAR_HAS_CLOSED)
{PlotSquareSubgraph[sc.Index] = sc.Close[sc.Index] ;}
And the following code to plot a square when the last price of a developing bar is equal to the prior bar's high:
if (sc.Close[sc.Index] == sc.High[sc.Index-1])
Instead, both codes do exactly the same: plot a square when the last price of a closed bar is equal to the prior bar's high.
I am thus unable to reference the last price of a developing bar. How can I do that?
Date Time Of Last Edit: 2017-06-16 00:35:34
[2017-06-16 18:24:14]
This code is wrong:
It needs to be sc.GetBarHasClosedStatus(sc.Index)
And make sure you are not using sc.GetBarHasClosedStatus anywhere else in the function.
You should also be aware of floating-point error:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scFormattedEvaluate
