Date/Time: Wed, 15 Jan 2025 09:50:45 +0000
Question on Trading Window Please...
View Count: 683
[2017-06-15 14:46:15] |
Quantico - Posts: 45 |
I find a way to disable certain buttons on the trading window but is there a way to remove certain buttons and fields. IOW I would like a smaller, stripped down version with only Buy/Sell Market, reverse, flatten and cancel,for scalping. Date Time Of Last Edit: 2017-06-15 14:47:29
[2017-06-15 16:54:12] |
There is not currently a way to actually remove buttons from or change the size of the Trade Window. Although there is the Compact tab. And the Trade Window can be detached by unchecking Trade >> Attach Trade Window to Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
