Date/Time: Wed, 15 Jan 2025 09:46:05 +0000
[Locked] - Click and move 'extending rectangle tool'
View Count: 1599
[2017-06-14 14:51:34] |
grantx - Posts: 244 |
I use the extending rectangle tool for all my levels and they get moved around a lot. Is there a quicker way to move them other than right clicking and selecting 'move drawing'? It would be so useful and a lot quicker/easier if I could CTRL+left click to move it....or simply clicking in the middle of it and moving it. I can move horizontal lines this way but not the extended rectangle. Date Time Of Last Edit: 2017-06-14 14:52:16
[2017-06-15 18:27:28] |
I guess thats a no?
[2017-06-15 18:30:41] |
All of the methods to move a Chart Drawing are documented here: Chart Drawing Tools: Move Drawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-15 18:35:19] |
Actually, for Rectangle drawings, there is another step. You need to use the Left Click Selection Method and once the drawing is selected you just need to left click again between the two vertical lines drawn within it to initiate the Move operation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-15 18:36:10
