Date/Time: Wed, 15 Jan 2025 09:47:28 +0000
charting
View Count: 674
[2017-06-14 12:40:23] |
User420048 - Posts: 17 |
Hi, I am on a free trial. I have been a cqg subscriber for 15 years. I am trying to embrace this system but I'm finding it very clumsy. Can you help me get up to speed. I'm more interested in trading than fumbling around with a charting package. Help please! Thanks, John |
[2017-06-14 13:12:58] |
So did you want to connect Sierra Chart to your CQG account? Currently we see you are using IQ Feed. It would be easier to use the Sierra Chart Exchange Data Feed and that is what we strongly recommend. We can help you get set up with that but to get the better pricing for the exchange fees, you need to be able to connect Sierra Chart to your CQG account. That will require some enablement's on your CQG account by your broker. These are explained here: CQG Trading Platform Service: CQG Account Requirements Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-14 17:40:24] |
Also, considering the comment you have made: . I am trying to embrace this system but I'm finding it very clumsy. We really would never be recommending using IQ Feed. That would be the last data feed we would recommend using for a new user. It should only be used by those who really know that is what they want to use for a certain reason. We strongly recommend that you move off of that onto the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php The Sierra Chart Exchange Data Feed is maintained by us and it has the best integration to Sierra Chart. You can also automatically list spread symbols and easily select them. And contact your broker to allow Sierra Chart to connect to your CQG account so that you can take advantage of the lower-priced exchange fees. Did you want a remote assistance session? That is available at USD.65 per minute. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
