Date/Time: Wed, 15 Jan 2025 09:27:41 +0000
Quote Board Fields
View Count: 1262
[2017-06-13 18:21:40] |
User103861 - Posts: 42 |
In addition to % Daily Change, would it be possible to add fields to the Quote Board for % Weekly Change & % Monthly Change?
[2017-06-14 18:18:38] |
These cannot be added to a Quote Board but there could be studies created which calculate these.
[2017-06-15 13:41:23] |
Thank you. Which study should I use, or would they be custom?
[2017-06-16 02:25:25] |
There is no existing study that automatically does specifically this.
