Date/Time: Wed, 15 Jan 2025 09:47:25 +0000
Chart Entry / Exit fill markers
View Count: 2581
[2017-06-13 17:17:44]
User989712 - Posts: 27
Is there a way to change the colors of the Chart Entry/Exit fill markers?
I would like to, for example, have Green for Long and Red for Short. The direction is fine...Right pointer for Entry and Left pointer for Exit.
I need a way to make these markers stand out from the chart background. I would use a bright green and a bright red.
I have the size set to large, but making them even bigger (Extra Large) in addition to being able to set the color would help.
I am turning off the text and the price portion of the markers.
Please advise, thanks
[2017-06-13 17:19:47]
to clarify,
on this particular chart I have a very small range bar, and the entry/exit markets are getting lost in the quantity of small bars.
[2017-06-13 17:20:56]
and I don't want to see text (order price / quantity) on the chart, too messy and confuses the eye for this type of trading...
thanks
[2017-06-13 17:24:07]
Yes. This is all documented here:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#DisplayingOrderFills
[2017-06-13 18:26:39]
Perfect...really like your software. Over time will have no more questions... :-)
I want to backup all configuration and customization files...to an archive drive I have...so I can easily restore all the settings I make if I loose the hard drive.
I found the .CHT file for the ChartBook.
What are the names of the other files that hold customizations / account information? (*.config +)
[2017-06-13 18:27:56]
Refer to help topic 15:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Date Time Of Last Edit: 2017-06-13 18:28:05
[2017-06-13 18:51:45]
Perfect, thanks.
