Date/Time: Wed, 22 Jan 2025 03:27:29 +0000
[Programming Help] - Price of some other symbols
View Count: 736
[2017-06-13 08:10:35] |
User105454 - Posts: 1 |
Hello, I never use Acsil. I try to start to make a new study. I check the documentation but I still do not find an answer. I would like to include prices of differents symbols into the same study. For sample, Open and close prices of Minidow, S&P500, Stoxx, etc.. Do I need to open every chart with that different symbol in the same time, or there is an other way ? In a second time I would like to make a condition to compare 2 prices together, like : If (price1 [symbol1] > price2 [symbol1]) and later in the same part, If (price1 [symbol2] > price2 [symbol2]). Thanks. |
[2017-06-13 17:42:26] |
If you just need to access the current prices for other symbols, then refer to: http://www.sierrachart.com/index.php?page=doc/ACSILProgrammingConcepts.html#AccessingCurrentSymbolDataForOtherSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-13 17:42:38
