Date/Time: Wed, 15 Jan 2025 05:54:00 +0000
Stage5 and OneUpTrader accounts...
View Count: 1716
[2017-06-12 23:57:11] |
User629089 - Posts: 93 |
Hi Support, I currently have a brokerage account with Stage5. In addition I would like to start the evaluation process through OneUpTrader, I believe a partner of yours or at least SC is compatible with OneUp. My question is, can you enter orders for both accounts at the same time through SC's order entry in effect placing the identical orders in the different accounts? Thanks... |
[2017-06-13 02:28:57] |
My question is, can you enter orders for both accounts at the same time through SC's order entry in effect placing the identical orders in the different accounts? No, this is not supported.
