Date/Time: Tue, 26 Nov 2024 03:36:32 +0000
LL_DISPLAY_VALUE
View Count: 1468
[2013-08-27 17:42:02] |
User53900 - Posts: 5 |
I have the drawstyle for the subgraphs of my custom study set to DRAWSTYLE_LINE, with the line style being LINESTYLE_SOLID. The attributes for the line label include LL_DISLAYVALUE and LL_VALUE_ALIGN_LEFT_EDGE. One can see in the attached chart that the left edge of the chart doesn't just display the values of the subgraphs for the current bar but sometimes subgraph values for previous bars as well, for example 1707.50 from yesterday. |
Private File |
[2013-08-27 18:50:58] |
Go into the Study Settings>> Subgraphs tab for the study and uncheck Always Show Name and Value Labels When Enabled.
[2024-01-04 19:10:16] |
binaryduke - Posts: 369 |
Can Always Show Name and Value Labels When Enabled be controlled via ACSIL? I can't seem to find a matching member or function.
Date Time Of Last Edit: 2024-01-04 19:13:55
[2024-01-05 02:42:28] |
Sierra_Chart Engineering - Posts: 17179 |
Yes we can add this.
[2024-01-06 10:50:03] |
A function for this has been added.
