Date/Time: Wed, 15 Jan 2025 05:16:49 +0000
Numbers bar and pullback column text color
View Count: 1122
[2017-06-12 19:37:06]
AlexPereira - Posts: 197
I am using NumbersBar study with a background color and custom color for text. It works perfectly in the "normal bars" but on the pullback column, the custom color for text isn't applied, which makes text almost impossible to read ( in the other bars, where custom color is applied, it reads nicelly ).
Can the custom color for text also be applied to the pullback column bar ?
Cheers
[2017-06-12 20:07:47]
This will be supported in the next release.
[2017-06-13 07:26:07]
Confirmed, just tested 1569 pre-release and its working nicelly :)
Thanks for the great support !
