Date/Time: Wed, 15 Jan 2025 05:45:39 +0000
Intraday Data Storage Time Unit impact on Volume Weighted Average Price Study
View Count: 1213
[2017-06-12 17:57:41] |
User995923 - Posts: 64 |
Hello I trade many forex pairs using charts with 30 minute bars or higher. However the software becomes extremely heavy and it needs too much time to load up the charts. I am using multiday VWAP and Volume by Price studies so I would like to know if VWAP and VBP will be affected if I change the IDSTU from tick data to 1-second or higher in order to increase the performance of my PC and the load time. Regards Andreas |
[2017-06-12 18:04:52] |
Yes there will be some change, but we do not think it should matter that much. Ultimately the decision is yours. In our opinion it is just fine and you should increase the Intraday Data Storage Time Unit, but others would think this is unacceptable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-12 18:05:19
