Date/Time: Wed, 15 Jan 2025 05:19:53 +0000
ACSIL UseGUIAttachedOrderSetting
View Count: 1845
[2017-06-12 05:55:04] |
rhovega - Posts: 279 |
I have an ACSIL trading system where the attached orders are given programatically by s_SCNewOrder. I would like to be able to toggle on/off between attached order settings provided by a) s_SCNewOrder, and b) the Chart Trade Window. I went over http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scUseGUIAttachedOrderSetting as well as over the provided example studies / source code. Tried "sc.UseGUIAttachedOrderSetting = true" together with "Use Attached Orders" enabled on the Trade Window. It didn't work. Cant it be that UseGUIAttachedOrderSetting does not override SCNewOrder? If so, is there another function for that, or do I need to tweak my code? Thanks Date Time Of Last Edit: 2017-06-12 06:05:45
[2017-06-12 06:05:10] |
Cant it be that UseGUIAttachedOrderSetting does not override SCNewOrder? No definitely not. If you want to use the Attached Orders on the Trade Window you cannot specify them with SCNewOrder. And what was previously specified will have already been set on the Trade Window for the chart the study is applied to.
