Date/Time: Wed, 15 Jan 2025 05:32:06 +0000
RTH-ETH background color
View Count: 1613
[2017-06-12 05:11:03] |
User294366 - Posts: 7 |
Can the background color for the RTH be different from the ETH background color? Thanks Dave
[2017-06-12 06:10:25] |
For this, you need to use the Time Range Highlight study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=278#Time_Range_Highlight Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
