Date/Time: Fri, 18 Sep 2026 02:47:06 +0000
Time Colored Volume Profile
View Count: 1480
| [2017-06-11 23:57:05] |
| User156428 - Posts: 4 |
Hi there, i got an idea i already missed in all paltform I use in the past. Is possible to create volume profile and split this profile by time. Lets say we look at the volume histogram by using a 30 min chart. I can see only the whole profile - it would be great if this opportunity exist. For me as a trader it make sometimes thing easier to see there in the profile was the biggest volume created. Its like the Market Profile with letters (can also use color split letters) with the difference its the volume profile - or in other words - a Market Profile based on volume. Best Arthur |
| [2017-06-12 20:29:29] |
Really the best way to do something like this is to use the Draw Volume Profile tool: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#DrawVolumeProfile You can then adjust the beginning and ending Date-Times to what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-12 20:30:05
| [2019-04-05 13:26:49] |
| User164231 - Posts: 281 |
Please do add a Time Colored VP. It is very useful for VP users and overlooked by other charting software.
