DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 15:12:34 +0000
Global Sybmol Settings when SC is client
View Count: 4209
[2017-06-11 21:08:08]
onnb - Posts: 664
When SC is a client is it possible to have the global symbol settings updated by the server?
I am currently receiving SECURITY_DEFINITION_FOR_SYMBOL_REQUEST and responding to that but nothing appears in the global symbol settings.
Also, when I press "Update From Server", I don't get SECURITY_DEFINITION_FOR_SYMBOL_REQUEST event.
My question is whether this is supported,supposed to work and if there is any documentation on this?
[2017-06-13 02:14:58]
DTC Engineering - Posts: 320
Refer to:
Data and Trading Communications (DTC) Protocol Test Client: Populating Symbol List in Sierra Chart
[2017-06-13 16:29:43]
onnb - Posts: 664
Just to see I understand - the idea is that when we have logon sequence we send in SECURITY_DEFINITION_RESPONSE for all the symbols we want to support.
1. If we set symbol X, then user makes changes to X and we do this again - I'm assuming that user's changes will get overriden
2. Just confirming that Update From Server button is not supported with DTC
Can you confirm above understanding?
[2017-06-13 16:39:16]
1. Yes this is correct.
2. No it is not supported.
You can also supply a GlobalSymbolSettings.XML file that a user can use with all of the symbols for the service. There are also certain symbol settings fields which could be used to utilize the symbol searching/retrieving capability on the Find Symbol window.
Date Time Of Last Edit: 2017-06-13 16:39:56
