Date/Time: Sat, 26 Apr 2025 09:42:42 +0000
Inhibit all sound from a chart
View Count: 1142
[2017-06-10 12:07:27] |
User360283 - Posts: 514 |
How can I easily inhibit all sounds from a specific chart without modifying all the alerts? Case is I have two identical charts. The only difference is the time frames. I want to retain the alerts on both, but do not want the sounds to occur on the longer time frame. I would like to simply set the sounds to off for the longer time frame chart. How can I do this? Thanks |
[2017-06-10 20:18:57] |
This is not supported. You can only disable all alert sounds.
