Date/Time: Wed, 15 Jan 2025 06:03:20 +0000
Question about the daily profit loss management option
View Count: 1003
[2017-06-10 03:47:16] |
User772556 - Posts: 21 |
I see there is an option that will lock the platform if a certain profit or loss is reached and you can set the amount of time for it to be locked. Can I go in an unlock this before the time expires or is it fully locked so that you cant go in and do more damage to your account?
[2017-06-10 07:10:30] |
This is actually documented right here: Global Profit/Loss Management: Lock Trading (Global Settings >> Global Profit/Loss Management) You can disable it at any time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-10 07:10:42
