Date/Time: Wed, 15 Jan 2025 05:37:05 +0000
Bar Spacing resets on Rollover
View Count: 922
[2017-06-09 19:07:36]
User299392 - Posts: 216
I have seen this happen where the bar spacing resets and produces shrunk bars on rollover.
Is there a way to either lock bar spacing or set a user default for it?
[2017-06-09 19:09:01]
This is in case of automatic rollovers.
[2017-06-12 14:18:01]
Sorry, but I have to ask...
Did you get a chance to address this issue?
Or a workaround on how to lock bar spacing?
[2017-06-12 19:39:33]
The problem is you have enabled this option:
http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#ResetBarSizeSpacingScaleOnSymbolChange
[2017-06-12 20:52:14]
Thank you indeed!
But that just resolves the problem of horizontal spacing; not vertical spacing.
Vertically the chart just shrinks when another symbol is called out - this happens both in case of another symbol altogether and also rollovers. Anything I can do for that not to happen?
[2017-06-12 21:06:33]
Make sure the Scale Range is Automatic. Refer to:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#ResetScales
Date Time Of Last Edit: 2017-06-12 21:07:19
[2017-06-12 21:07:27]
We gave the wrong link in the prior post. It has been corrected.
