Date/Time: Wed, 15 Jan 2025 06:17:04 +0000
User Question
View Count: 679
[2017-06-09 16:30:01] |
Sierra Chart - Max - Posts: 5778 |
Hi. When will Sierra-chart support Millisecond timestamps?
Thank you. Sierra Chart Support |
[2017-06-09 18:15:56] |
We can only say that we expect to work on it this year. Most likely will start on it in September.
