Date/Time: Wed, 15 Jan 2025 06:26:22 +0000
Dedicated server
View Count: 1421
[2017-06-09 16:17:50] |
JamesP - Posts: 89 |
It was previously mentioned that you recommend https://www.amanah.com/Dedicated-Servers/ as a good option for a dedicated server, do you still think this is a good option? I've only ever used windows so I'm wondering what's involved in using SC on their offered operating systems?(windows is extra) Here is a list. CentOS 6.X x86_64 (Default) CentOS 7.X x86_64 CentOS 5.X x86_64 Debian 8.x x86_64 Debian 7.x x86_64 Ubuntu 16.x LTS x86_64 Ubuntu 14.0x LTS x86_64 Ubuntu 12.0x.1 LTS x86_64 vSphere Hypervisor 6 FreeBSD 10.x VMware vSphere Hypervisor 6 |
[2017-06-09 16:41:10] |
That was one particular dedicated server provider, that had inexpensive fully dedicated servers. Although you can use any service. You really should use Windows. It is going to be a whole lot easier. We really do not recommend any other operating system. Also you can buy your own copy of a Windows server 2012, for about USD150. Just check on eBay. But you have to install it though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-09 16:41:55
