Date/Time: Wed, 15 Jan 2025 06:01:59 +0000
ACSIL flat a single order
View Count: 649
[2017-06-09 16:11:08] |
wwwingman - Posts: 185 |
Hi Is it possible to to flatten a position using a working exit order ? Ex: position is 1 open long, and 1 short limit working. I have multiple simultaneous trades so cannot use the flatten functions. I wanted to use the sc.ModifyOrder but I cannot change the order type (which seams normal..). Please advise. Maybe I am missing something. -- w. |
[2017-06-09 16:20:04] |
Yes this is possible. Just enter an order with the opposite side and quantity you want to reduce the Position by. You can use sc.BuyExit or sc.SellExit. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
