Date/Time: Wed, 15 Jan 2025 05:40:48 +0000
Pulling/Stacking going beyond 10 depth levels?
View Count: 1740
[2017-06-09 16:10:19] |
User839162 - Posts: 87 |
This is the mini-nikkei 225 and I had to reduce the number of depth levels to 10. Well when I did this the pulling/stacking didn't reduce to 10 with it. Is it possible to reduce the number of pulling/stacking levels to match the 10 depth levels? Thanks Date Time Of Last Edit: 2017-06-09 16:11:17
SierraChart_2017-06-09_10-02-25.png / V - Attached On 2017-06-09 16:09:50 UTC - Size: 127.71 KB - 592 views |
[2017-06-09 16:51:43] |
Refer to this setting: Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-12 01:10:17] |
I set the pulling/stacking to 5 and I'm still getting more than 5 levels? See attached image.
Capture.PNG / V - Attached On 2017-06-12 01:09:52 UTC - Size: 237.22 KB - 718 views |
[2017-06-12 04:02:24] |
We will look into this. This will be resolved in the next release.
