Date/Time: Wed, 15 Jan 2025 06:03:31 +0000
QuoteBoard and Associated Watchlist questions
View Count: 817
[2017-06-09 07:36:36] |
ticinotrader - Posts: 397 |
Dear Support, 1. Is it possible to make the Quoteboard scrollable? I have numerous instruments listed but I can scroll the list using the scroll bar only but mouse scrolling does not work. 2. Because of the number of symbols (70+) I have in a watchlist I mainly use Associated Watchlists to avoid unnecessary data download in the background and it is more convenient for me because during a session I make several modifications (grouping/ordering/adding/removing symbols etc) to a list. When I finish my session, I close the application and the changes are saved when the chartbook is saved so the list is available in the next session. My only problem is that when I unintentionally hit 'ESC' key, the Watchlist closes and I lose any modifications I just made. Would it be possible to prohibit Associated Watchlist to close on 'ESC' or add an autosave feature what saves any modifications? Thank you! |
[2017-06-09 18:27:17] |
1. We will see about this. 2. My only problem is that when I unintentionally hit 'ESC' key, the Watchlist closes and I lose any modifications I just made. We will look into this, but you definitely will not lose any changes when it is closed in this way.
