Date/Time: Wed, 15 Jan 2025 15:44:26 +0000
Spread-Butterfly study
View Count: 1087
[2017-06-09 03:41:49] |
User841161 - Posts: 229 |
Is there any videos out there showing examples of using spread-butterfly studies
[2017-06-09 18:04:59] |
The Spread-Butterfly study is very simple. Here is the documentation for it: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=259#Spread_-_Butterfly Let us know if it is still not clear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-03 19:55:57] |
User609223 - Posts: 1 |
I am also trying to use the butterfly studie, however i am unable to get the correct butterfly on my chart. When using tradingview is do it like this: 3*ZF-2*ZN-(3*ZN-UB) Now my calculation in tradingview can be wrong, but i think it is correct? So if it is correct, what is the right way to put it in the butterfly study? |
[2017-07-05 05:17:22] |
The Spread-Butterfly study does not support exactly the formula that you require. It is documented here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=259#Spread_-_Butterfly Is that formula an exchange listed spread? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-05 05:17:41
