Date/Time: Wed, 15 Jan 2025 06:13:31 +0000
Chart reset
View Count: 630
[2017-06-08 19:57:47] |
conr - Posts: 204 |
Running 1564, charting ES continuous. Shutdown Sierra last night and restarted this AM so as to get the adjusted contract. Every single one of my ES charts(numerous) changed the setting to 'Use Evening Setting.' I then had to go and change back every chart and then had to wait for everything to reload. This has happened before. Any idea why this is happening?
[2017-06-09 01:18:10] |
You need to disable the setting of the Session Times. Refer to: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
