Date/Time: Tue, 04 Nov 2025 18:08:35 +0000
How to connect to SC Real Time and IB
View Count: 2497
| [2013-04-03 12:47:52] |
| User88901 - Posts: 33 |
Hi is it possible to connect to the SC Market Stats data feed and then a primary feed like Interactive Brokers at the same time for charting from both feeds? And if so can I get a link for how to do it? Thank you
| [2013-04-03 16:10:29] |
Yes. There is nothing special to do to make this work. You can open the Market Stats charts through File >> Find Symbol.
