Date/Time: Wed, 15 Jan 2025 06:19:25 +0000
Quote board values incorrect
View Count: 1106
[2017-06-08 13:46:18]
User207239 - Posts: 6
Hello, I am seeing some discrepancies on the quote board in the ChangeFromOpen fields. Is there a way fix this this? The values are off quite a bit. Also the DlyChange% field has stopped updating for the forex-x indexes. Thanks in advance.
[2017-06-08 19:23:45]
Is the Daily Open value as you would expect for the symbol?
We will look into this.
[2017-06-08 21:24:42]
I hadn't looked at that, but no the daily open on the quote board is off as well by about 60pips from the prior close on the EUR/USD. Thanks
[2017-06-09 05:49:46]
The Daily Open is not always going to match the prior settlement.
So you are noticing an issue with the symbol EURUSD?
Date Time Of Last Edit: 2017-06-09 05:49:51
[2017-06-09 17:40:30]
Yes, I understand the bid widening there on the close can create a discrepancy. Honestly it looks a lot better today so maybe just something that was fixed when the day rolled over idk but I'm not particularly worried about it anymore as daily change seems more or less correct. However, I do have one other question for you. What is the best way to go about correcting gaps in the cfd data. For instance, I have gaps across the GBP pairs from when the election poll was released? Is there a setting to fill these types of gaps without correcting the bar manually? Thanks for your help.
-Alex
Date Time Of Last Edit: 2017-06-09 17:41:34
[2017-06-11 18:12:21]
There is no study or setting that does this. However, a study could be developed.
