Date/Time: Wed, 15 Jan 2025 05:43:38 +0000
numbers bars
View Count: 918
[2017-06-07 17:09:30]
User144295 - Posts: 70
Hi Sierra Team,
I am aware of change of numbers bars as of 1558 Release Date: 2017-05-12.
My color diagonal scheme is depended on previous versions setup.
How can I possibly upgrade to new version (because one day I will need to anyway) and keep my current numbers bars set so the colors are not affected?
Thank you
[2017-06-07 18:01:53]
There is nothing with the changes of the Numbers Bar study which will prevent you from doing what you have been doing previously. And there normally will not be any changes to Input settings needed.
[2017-06-07 20:10:53]
Yes, but after upgrade to 1558 the colors of the number bars has completely changed comparing to 1556 version based on my original diagonal settings.
[2017-06-07 21:57:26]
Can you tell us how you want to do the coloring, including the coloring method and percentages and we will create a Study Collection to do this.
Although first update to Prerelease 1566 because we have made some small changes and resolved a couple of issues related to the changes. That may actually solve it for you.
[2017-06-08 12:18:10]
Thank you. The screen shows my current numbers bars setup and second screen shows how it looks in 1556. I picked one bar from yesterday NQ market 9:40 for illustration. The third screen shows how it looks with the same setup on 1558 and later versions including current prerelease 1566. I would like to get same coloring as in 1556 and older version. Thank you.
Private File
Private File
Private File
[2017-06-08 14:56:23]
It appears as though the Percent thresholds did not update properly. In the latest version, set this particular Input:
Numbers Bars: Column # Percent Compare Thresholds (Column 1 Percent Compare Thresholds)
To:
.4, 1, 1.5
Date Time Of Last Edit: 2017-06-08 14:56:40
