Date/Time: Wed, 15 Jan 2025 05:59:24 +0000
upgraded to 1564 from 1307 but new spreadsheets don't connect to IB
View Count: 694
[2017-06-07 15:33:25] |
auggie - Posts: 45 |
My charts are updating with IB but the new spreadsheet is not connecting. Larry |
[2017-06-07 15:55:02] |
OK, I figured out that you have to choose "quote spreadsheet" but I have another question. If I want to move the Volume column to the right of the DailyChange% column can I just do a cut and then insert like in Excel? Larry |
[2017-06-07 16:00:19] |
We did not understand the issue at first but now we understand that you are using a Quote Spreadsheet and it was not receiving updates. To reorder columns this is done through Global Settings >> Quote Spreadsheet Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
