Date/Time: Wed, 15 Jan 2025 06:26:21 +0000
Trade and Quote symbol and currency value of tick size
View Count: 1071
[2017-06-07 10:40:08] |
AlexPereira - Posts: 197 |
Hi, I have a doubt about "Trade and Quote Symbol" usage: Would it not make sense for the chart using this feature, to have the "currency value of tick size" to the actual traded symbol ? Example: LMAX has a GDAXI and GDAXIm. Both are the same, but GDAXI is a 2.5 times contract and GDAXIm is a normal contract. Would it not make sense when using GDAXI symbol with "Trade and Quote Symbol" for GDAXIm, for the "currency value of tick size" be the GDAXIm value ( 1 contract, not 2.5, applied to chart when clicking "Apply global settings" ) ? That would display the proper profit or loss. Is it OK to modify "currency value of tick size" manually to the underlying traded symbol ? Thanks. |
[2017-06-09 01:58:47] |
Would it not make sense for the chart using this feature, to have the "currency value of tick size" to the actual traded symbol ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
