Date/Time: Wed, 15 Jan 2025 05:01:14 +0000
Cannot connect to data
View Count: 867
[2017-06-06 19:57:45] |
James Davenport - Posts: 1 |
New free trial account. At step 7 of the Getting Started instructions. Cannot connect software will not connect to the SC data feed. The "connect to data fees" selection if not active nor is the "con" button on the task bar.
[2017-06-06 20:17:01] |
This means that Sierra Chart is already connected.
