Date/Time: Sun, 19 Jan 2025 09:08:41 +0000
[Programming Help] - delta divergence help
View Count: 2697
[2017-06-06 17:49:26]
amk44 - Posts: 10
Can someone give me the simple alert formula to make a red arrow over the candlestick when the bid volume is positive but the candlestick closes lower. And green arrow under the candle stick when the ask volume is negative but the candlestick closes higher. I'm having problem with how to set up the simple alert.
Thanks in advance, Alan kennedy
[2017-06-07 08:21:08]
Marmany - Posts: 307
I attach a study which does what you require. It is for use on tick charts, signals when bar 90% complete and within 2 x ATR of HOD or LOD(the values being pulled in from another chart). Feel free to chop out the code you do not need. My email is in the study, let me know if you need further explanation.
attachmentDPdivergence.cpp - Attached On 2017-06-07 08:12:00 UTC - Size: 4.14 KB - 653 views
[2017-06-07 19:34:51]
This custom study will need to be compiled into a DLL. Refer to the instructions here:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
[2018-04-01 19:56:21]
User342238 - Posts: 44
I am also looking for this indicator. Will this one work on a time based chart?
Thanks,
