Date/Time: Fri, 29 Mar 2024 15:08:01 +0000
Total for Current traded bid ask volume
View Count: 2892
[2017-06-06 17:44:58] |
grantx - Posts: 244 |
On the DOM there is an option to clear the 'Current traded bid ask volume' columns. Is there a way to see the total volume that has traded for the BID and ASK side (separately) since I last cleared? It would be very helpful to see the total of these columns printed somewhere. |
[2017-06-07 07:26:48] |
Not sure we understand the question. Those market data columns will do just what you say. Here is the documentation: Global Trade Settings Windows: Current Traded Bid Volume - Left/Center/Right Aligned Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-07 08:33:43] |
See screenshot. Total of that particular column. Gets reset to zero when I clear the column. Date Time Of Last Edit: 2017-06-07 08:35:20
F.US.CLEN17 #2 2017-06-07 09_26_58.941.png / V - Attached On 2017-06-07 08:32:38 UTC - Size: 29.32 KB - 511 views |
[2017-06-07 18:45:57] |
With how we understand what you are looking for, this is not supported.
[2018-04-13 13:18:28] |
lpfin123 - Posts: 59 |
Good morning, What Grantx is asking is something I would definitively use also (I was actually looking if it was a feature), a summation of all the levels of the Current Bid Traded and a summation of all the levels of the Current Ask Traded, which would reset once the "Clear Current Traded Bid and Ask Volume" is hit. 1- Is this something that could be added? Thank you, 2- For my personal information, is there a process to make suggestions or the way I did it is fine? |
[2018-04-13 18:17:35] |
1. We will look into this. 2. This is the correct way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-13 23:23:47] |
User120942 - Posts: 71 |
Has there been any updates on this request? I am also interested in being able to see the total cumulative count on the bid and the ask that is displayed on the current traded bid/ask volume columns. That values would revert to 0 once the columns are cleared and the summation of the bid and ask totals would restart. Or can the Text Display for Study be applied to the Chart DOM and Regular DOM that can provide the following values: Total current traded bid, total current traded ask and difference between the total traded ask - the total traded bid in sierra. |
[2019-02-26 22:46:40] |
No we have not yet gotten to this. A custom study can be made to do this though. Refer to these functions: sc.GetCurrentTradedAskVolumeAtPrice() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-20 21:56:17] |
@sstfrederik - Posts: 401 |
I have a test version ready for interested folks in this thread. Contact me if you want to test it before I release it on the SST website. Frederik frederik@simplesystemtrading.com |
