Date/Time: Wed, 15 Jan 2025 06:22:06 +0000
Chart Settings - session times space messed up
View Count: 1066
[2017-06-06 14:32:08] |
User299392 - Posts: 216 |
Session times does not let you enter hour or even minutes and second space has just one digit. See image below. |
Chart Settings - times messed up.JPG / V - Attached On 2017-06-06 14:32:02 UTC - Size: 183.32 KB - 287 views |
[2017-06-06 14:32:37] |
This is across the board now.
[2017-06-06 15:22:47] |
Refer to: Notice: Windows 10 Update Causes Date/Time Controls to Not Display Properly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-09 19:47:38] |
Any ETA ON this?
[2017-06-09 20:02:45] |
This is now resolved. Update Sierra Chart with Help >> Current Version.
