Date/Time: Wed, 15 Jan 2025 05:23:32 +0000
Trade DOM Template-Columns
View Count: 1258
[2017-06-06 14:25:55] |
User46129 - Posts: 22 |
There must be a way to do this,but I'm not finding it and apologize in advance for the dumb support ticket. Would like to set global columns for trade DOM, so that each time I open a new DOM, the same columns appear in the same format as shown in attached.
2017-06-06_0921_DOM.png / V - Attached On 2017-06-06 14:24:17 UTC - Size: 124.03 KB - 918 views |
[2017-06-07 15:47:01] |
Refer to Chart Templates: Using Chart Templates: Duplicating Charts / Template Charts The way to do this is to duplicate an existing Trading DOM window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
