Date/Time: Wed, 15 Jan 2025 13:00:23 +0000
Multiple independent entries with attached StopLoss and Profit Target
View Count: 1199
[2017-06-06 11:13:47]
User287992 - Posts: 51
Is it possible to achieve entries with independent attached StopLoss and Profit Target orders while using ACSIL studies? Only behavior I was able to see is increased size of SL/PT orders after additional market entries. I would like to have SL/PT for each entry instead.
Thank you in advance for any help.
[2017-06-06 17:35:06]
Yes. This is the standard functioning so long as you have not set Support Scale In or Support Scale Out. Refer to:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scSupportTradingScaleIn
There is nothing special to do. The orders will always be separate with their own Attached Orders automatically.
[2017-06-16 15:07:16]
Thank you. I had to explicitly add
sc.SupportTradingScaleIn = false;
into strategy to override settings in trade window.
[2017-06-19 12:31:49]
I have another problem regarding this. The entries and exits are not correctly connected in chart and trade activity log.
For example the following trades have PT and SL 20 ticks:
Symbol Trade Type Entry DateTime Exit DateTime Avg Entry Price Avg Exit Price
[Sim]GC-201708-NYMEX Short 2013-01-03 13:21:37.049 2013-01-03 14:12:07.001 1715.9 1717.0
[Sim]GC-201708-NYMEX Short 2013-01-03 13:33:13.070 2013-01-03 13:46:16.001 1715.0 1715.8
[Sim]GC-201708-NYMEX Short 2013-01-03 13:37:33.004 2013-01-03 13:37:33.010 1713.8 1713.9
Correctly it should be:
1715.9 => 1713.9
1715.0 => 1717.0
1713.8 => 1715.8
http://www.sierrachart.com/image.php?Image=1497875349884.png
Is there any way to fix it?
Thank you.
Private File
Private File
[2017-06-20 20:21:51]
Refer to the documentation here about this:
http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#OrderFillMatchingMethods
Also, refer to:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#OrderFillConnectingLinesDoNotDisplay
[2017-06-21 12:00:06]
Thank you. Sadly neither FIFO nor FILO satisfies all cases. If we have 3 orders:
Long Entry SL PT
1. 1000 980 1020
2. 1005 985 1025
3. 1010 990 1030
If the price will go up from 1010, then it will fill FIFO but if it will go down it will fill FILO.
It would be great if SC could connect those trades based on parent/child connection that causes those fills.
[2017-06-26 10:30:49]
Will this functionality be part of SC? It would help us a lot, thank you.
[2017-06-26 14:50:48]
How orders are grouped and matched is documented here:
This will not change. Also check the Open/Close field to make sure it is correct for those order fills.
[2017-06-26 16:47:26]
Open/Close field is correct based on documentation but those trades are not real because neither FIFO nor FILO matches all trades correctly.
I understand the way FILO and FIFO work and I am not asking you to change anything about it. But having multiple positions (and trying to use Trade Activity Log) right now seems very counter-intuitive, illogical and wrong, since trades are matched incorrectly. Please see enclosed tradelist to ilustrate how useless it is, since I am not able to analyze my trades the way I took them. Profit Target and Stop Loss is 20 ticks for every trade.
imagePasted image at 2017_06_26 06_39 PM.png / V - Attached On 2017-06-26 16:46:40 UTC - Size: 251.15 KB - 295 views
