Date/Time: Wed, 15 Jan 2025 14:12:00 +0000
Bartime
View Count: 1021
[2017-06-06 01:28:20] |
Crtfyd - Posts: 281 |
Since I downloaded the latest version a couple days ago, my Bartimes don't work correctly. I attached a screenshot (the only way to show graph and studies alert condition at same time). As you can see I have Bartime set for >9:29.58 (this is a one second chart and all the bars are present[ie:no missing bars]) and < 9:30.00 for the "Colored Bar based on Alert" represent as the large down RED arrow. But the arrows start showing up at 9:29.51 I've switched times around and nothing effects it. b4 downloading the latest version I didnt have this problem. Is there any other way to show a Bartime for the 9:29:59 bar only? Thank you. |
[2017-06-06 02:08:13] |
The formula does not look correct to us. The denominator should be seconds and not minutes. Easiest just to use this Spreadsheet function: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#TIME_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-27 08:27:58] |
In this thread, you can see that we referred you to use the TIME function.
