Date/Time: Wed, 15 Jan 2025 04:46:32 +0000
Multiple positions/contracts of the same instrument opened and their PnL.
View Count: 773
[2017-06-05 18:37:53] |
User718694 - Posts: 25 |
When I have several positions opened for the same instrument (bought at different price levels), I can see the average price of the instrument and cumulative PnL. Is it possible to see/display an individual performance/PnL for each entry or do I have to calculate it manually? |
[2017-06-05 18:58:51] |
There is no way to see these individual entries/Positions. They are consolidated into one. However, you can use the Trades tab of the Trade Activity Log and use a Fill to Fill order grouping to get what you are looking for: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#TradesTab At least after the Positions are closed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-05 19:00:05
[2017-06-05 19:11:49] |
Ok, will have a look. Another question though, is it possible to include commissions and display it in the cumulative PnL of the opened positions on the chart?
[2017-06-05 19:25:36] |
There is a Round Turn Commission Symbol Setting but it is not supported outside of the Trade Activity Log.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-05 19:25:58
