Date/Time: Sun, 26 Jan 2025 07:35:31 +0000
Longerterm Portfolio Tracking of Buy Sell orders and statistics
View Count: 1319
[2017-06-05 15:55:51] |
ilcaa - Posts: 9 |
hi i am new to SC. I love the analysis ability SC provides, but i also am looking for a portfoliotracker software which can track buy/sell order and oter statistics i calculate on groups of securities based on maybe sectors/industries like Sharpe ratio and other risk measures (basic math calculations). before looking out side of SC, is this possible in SC? I know there is a Spreadsheet component but will this allow to be build a portfolio-tracker for open position and closed positions? any samples would be appreciate if so. thanks |
[2017-06-05 18:00:13] |
Have a look at the Trade Activity Log which also includes the Trade Statistics and Trades tabs: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php You can export the order fills from there if the capabilities you need do not exist there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-14 18:12:21] |
ARDAN - Posts: 66 |
What about "the stop offset value/stop all" in the attached orders window which is not there? Is there a way to grab it via spreadsheet study or ACSIL? Thanks. |
[2019-02-14 18:47:54] |
No, this is just not supported. It is just not supported. You are asking for all kinds of things which are just not supported. Understand that. You can set Attached Orders from ACSIL but not access the current ones set on the associated Trade Window for the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-14 18:48:57
[2019-02-14 20:27:09] |
ARDAN - Posts: 66 |
Yes as I try to read entire documentation and then search support board for my needs, It will be absurd If I ask all kinds of things which are supported. Can I write to text tag via ACSIL? Then I write my risked amount to there for each trade. Thanks. |
[2019-02-16 22:18:56] |
We could add a new function to support this in ACSIL, to set the Text Tag on the trade window. Let us know if that is what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
