Date/Time: Wed, 15 Jan 2025 04:54:35 +0000
Smoothing Lines
View Count: 1234
[2017-06-05 12:41:23] |
User28914 - Posts: 87 |
Is there a way to apply "smoothing" to indicators? Linear Reg Line = 95 EMA with a smoothing of 7 70 EMA smooth of 20 20 EMA with a smooth of 4 Keltner Channel = 26 3.25 with a smooth of 8 Thoughts? |
[2017-06-05 18:27:01] |
Yes. You can use the Based On setting with one of the Moving Average studies. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-05 18:27:30
