Date/Time: Wed, 15 Jan 2025 04:55:23 +0000
Probable incompatibility with MSVC 15
View Count: 753
[2017-06-05 11:30:45]
User28317 - Posts: 149
I encountered a recent problem with the DLLs of my Strategy. Specifically, I can't load them anymore as I get Windows Error Code 193. I tested it with various older versions of my strategy, and it seems that DLLs previously working stopped doing so. This happens as long as I don't go back to the strategies I created with Visual Studio 2015, which leads me to suspect that some recent Update doesn't like the most recent compiler, the one used in Visual Studio 2017.
I tried to run Sierra Chart in compatibility mode and I inspected my DLL with dependency walker just to check that it exposed the functions. The functions are there and compatibility mode didn't do anything.
Now, is there anything that I can do aside from downgrading my development setup or switch to GCC/LLVM?
Are there indications that such a thing would fix the problem?
[2017-06-05 18:46:25]
Error code 193 means:
%1 is not a valid Win32 application.
We made some changes to the Sierra Chart build which we want to see if resolves the problem. Update to prerelease 1566 following these instructions:
http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate
Also make sure the DLL statically links to the C++ runtime libraries.
Date Time Of Last Edit: 2017-06-05 18:46:52
