Date/Time: Wed, 15 Jan 2025 05:07:36 +0000
Chart Tabs not colored
View Count: 596
[2017-06-05 05:15:26] |
nicktrader - Posts: 728 |
I am working with linked charts and it seems that the previous colored Charts Tabs now not colored. I work with vers. 1564 |
Chart Tab not colored.png / V - Attached On 2017-06-05 05:12:22 UTC - Size: 1.76 KB - 241 views |
[2017-06-05 18:48:38] |
This has to be enabled and is documented here: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#ColorChartTabsWithChartLinkNumberColor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
