DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
 - Search Board |
 - Control Panel |
 - View My Posts / Threads |
 - Direct Messages
Date/Time: Tue, 04 Nov 2025 15:12:41 +0000
volume with decimal points
View Count: 4102
|   [2017-06-05 04:36:22]     |
| onnb - Posts: 664 |
                Working on a crypto currencies DTC server. When calling MARKET_DATA_UPDATE_TRADE, can I send in volume with decimal places? Does SC handle that ok?  |
|   [2017-06-06 04:40:51]     |
                Sierra Chart can only work with Integers.  The Volume Display Format setting in Global Settings >> Symbol Settings will then adjust those integers into fractional values when displayed. Date Time Of Last Edit: 2017-06-06 06:39:33
|   [2017-06-06 06:20:37]     |
| onnb - Posts: 664 |
                just to see I understand say we want to capture volume with 2 digit precision. If volume is 5.75, we would be sending 575 to SC through the DTC api In the symbol settings, I would set the value format to 0.01 I should then expect to see 5.75 in the T&S window?  |
|   [2017-06-06 06:39:01]     |
                 If volume is 5.75, we would be sending 575 to SC through the DTC api In the symbol settings, I would set the value format to 0.01  |
