Date/Time: Wed, 15 Jan 2025 04:55:37 +0000
E6M17, ESM17and NQM17 data issues
View Count: 840
[2017-06-04 23:31:31] |
User223734 - Posts: 103 |
Dear Sir, THe above data is not active , please check. |
[2017-06-04 23:33:53] |
Refer to: NOTICE: Sierra Chart Exchange Data Feed Interruption The problem is being worked on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-04 23:39:03] |
Please let me know when it is function again. Besides, the HSI with market depth isn't on auto renew status. |
[2017-06-04 23:41:25] |
I mean the HKFE (HSI) with market depth isn't on auto renewal status
[2017-06-05 00:10:50] |
The CME data is now working.
[2017-06-05 00:16:48] |
Thank you.
[2017-06-05 00:17:33] |
Please also advise why the HKFE (HSI) with market depth isn't on auto renewal status.
[2017-06-05 02:48:44] |
It is now set to renew.
[2017-06-05 02:50:34] |
Thank you
