Date/Time: Sat, 26 Apr 2025 09:42:43 +0000
How to find symbol for option
View Count: 3259
[2017-06-03 22:49:17]
User972044 - Posts: 154
Hi there,
I am trying to display quotes and option chains for an option. I am with IB and I do have market data subscription for all options but when I go to "File-Find a Symbol", I cannot find options in the choice, just stocks, CFD's and etc.
Please help. Thank you.
[2017-06-06 06:57:05]
The Interactive Brokers options symbol format is documented here:
Interactive Brokers Symbols: Options Format
Option chains are not supported in Sierra Chart.
[2017-06-06 07:17:28]
I have visited the link already and am aware of the format of option symbols for IB. My question is how do I pull up these option symbols in Sierra Charts let's say for a chart? If you go to "File - Find a symbol" in Sierra Charts, you don't see a category for "Option", so how do I pull up an option in Sierra Charts? That's my question.
[2017-06-06 08:30:42]
You cannot. You must manually enter the symbols.
This is explained on this page:
[2017-06-25 22:02:01]
Can those symbols be in C++ string format or do they have to be in SCSTRING format when I use them in my ACSIL codes?
[2017-06-26 15:23:05]
This question does not make sense. A symbol text string is a text string. The object type it is assigned to or contained in, is irrelevant.
This is not a question that makes any sense being asked to begin with.
Date Time Of Last Edit: 2017-06-26 15:23:36
[2017-06-26 17:15:41]
What I am trying to ask is what variable types of text string does s_SCNewOrder::Symbol take when I need to use this function, is it SCSTRING, C++, const* char ? Sierra Charts chooses to create another class SCSTRING to be used for text strings in certain study functions, class structure members and etc. instead of just allowing the more intuitive and comprehensive C++ string class to be used and sometimes it insists on const* char to be used, so I need to ask in order to program accordingly. May I make a suggestion to you? When you are not able to understand a user's question, can you please just ask the user to clarify instead of just dismissing user's question as "does not make sense"? Many times, I have to simplify my question because when my question is too long and too specific, you won't understand either. So if the question is too simple and you need more information, just ask the user to clarify. Much appreciated.
Anyway, I think I found the answer, am testing it right now just to be sure.
Date Time Of Last Edit: 2017-06-26 17:20:40
[2017-06-26 17:50:39]
It does not matter. It can be a plain C++ string or a SCString or a C++ string class when using the c_str() function.
Date Time Of Last Edit: 2017-06-27 18:17:54
[2017-06-26 19:57:04]
Well actually it does. For the study function sc.GetBasicSymbolData(Symbol,BasicSymbolData, true), the first parameter "Symbol" can only take const char*. I tried to pass a C++ string to it and I received an compiling error saying that the parameter is of the wrong type and cannot be converted. I had to use a const char*; I couldn't even use SCSTRING. So maybe for s_SCNewOrder::Symbol, it does not matter but for the sc.GetBasicSymbolData(Symbol,BasicSymbolData, true) function, it does, that's why I asked.
I actually would love it that it does not matter either for that "Symbol" parameter for the sc.GetBasicSymbolData(Symbol,BasicSymbolData, true) study function because I wanted to pass a whole bunch of option symbols with different strike price to that function to get different prices and I couldn't; I had to use const char* and please correct me if I am wrong, const char* is a pointer to an immutable variable, a constant that cannot be changed. I had to use a different constant for each different option just because of the different strike price or choose to be stuck with just one option symbol. So if you tell me that const char* is the same as any text string that's extracted with the c_str() method from the C++ string class, then I would love to try it with the sc.GetBasicSymbolData(Symbol,BasicSymbolData, true) study function.
Anyway, thanks for the reply.
Date Time Of Last Edit: 2017-06-26 22:12:45
[2017-06-27 18:19:13]
Refer to the examples here:
http://www.sierrachart.com/index.php?page=doc/ACSILProgrammingConcepts.html#FunctionsThatUseConstantCharacterPointerOrSCStringParameters
[2017-06-27 20:55:21]
Appreciate the addition in documentation to clarify but as far as I know "AddMessageToLog" is a function sc.AddMessageToLog() according to the documentation ACSIL Interface Members - Functions: sc.AddMessageToLog() not just "AddMessageToLog". I don't know if that "sc" before the function name makes a difference.
Date Time Of Last Edit: 2017-06-27 20:55:50
[2017-06-27 21:06:03]
Yes that is true. We just quickly put that together this morning. We will correct the documentation.
