Date/Time: Thu, 10 Sep 2026 01:06:53 +0000
Not able to display intraday data for SVXY symbol
View Count: 1142
[2017-06-03 21:59:40]
User972044 - Posts: 154
Hello there,
I am trying to display the hourly chart for SVXY but I am not able to. I am only able to display the daily chart for the symbol. I have a trading account with IB and I do have the market data subscription for real-time data from the exchange where SVXY is traded on. And I do get real-time hourly data for SVXY in TWS.
Please help. Thank you
[2017-06-04 06:00:37]
Make sure you are using the correct symbol. Refer to:
https://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock
You may need to use the symbol format which also specifies the Primary Exchange.
Date Time Of Last Edit: 2017-06-04 06:00:48
[2017-06-04 07:55:44]
I do have the correct symbol otherwise even the daily chart wouldn't even load. I switched to the Hourly chart and it's loading now. It's just very very very slow.
I will let you know if I have further problems. Thanks
[2017-06-04 08:27:54]
Ok I have a new problem now. I was able to load the hourly chart data for SVXY but it would only load until 2017 04-07 when in the "From" field in the Chart Settings, I specified I want to load all the intraday data all the way from 2011-04-02. Attached please see the screenshot image that shows the date range that I specified for the intraday chart. I was able to see all the data back to 2011 in TWS and I want to see the same thing in Sierra Charts but Sierra Charts is only able to load the data from 2017-04-05.
And if I choose "Historical Chart" in the Chart Settings, it only displays price data from 2016-06-02.
Please advise how can I see all the intraday data for this symbol from 2011.
Thank you.
Date Time Of Last Edit: 2017-06-06 16:40:59
Private File
[2017-06-06 04:54:51]
Can I follow up on this? I am still not able to load intraday data before 2017-04-07. As soon as I put in a date earlier than 2017-04-07 in the "From" field, it automatically reverts back to 2017-04-07, can somebody investigate why this is the case? I need historical data for backtesting.
Thank you.
[2017-06-06 05:54:40]
You need to follow the instructions here to use the Sierra Chart Historical Data Service:
Interactive Brokers Trading Service: Using Sierra Chart Historical Data
You cannot rely on the historical data from Interactive Brokers.
[2017-06-06 07:30:30]
Ok if I get the Sierra Charts Historical Data Service, would I still be able to get the real-time price data from IB in addition to the historical data?
[2017-06-06 07:53:24]
Actually we just noticed your service package is on 1 which has been discontinued. We have set it to 3. So you now have access to that service.
The real-time data will still come from Interactive Brokers.
[2017-06-06 08:02:44]
Ok thank you so much. I am just testing something out. Once it works out, will continue to subscribe to standard package 3.
[2017-06-06 16:32:32]
Nothing is changed. I exited Sierra Charts and relogged back in and set the "From" date to 2011-04-02 to try to download all the historical price data from 2011-04-02 but it still does NOT work. As soon as I hit "Yes" to redownload the historical data, the "From" field automatically reverts back to 2017-04-05 in the "Date Range" section. The starting date in the "Use Date Range" section does not apply at all even though I specified the starting date as 2011-04-05.
Please investigate and advise. I only have TWO full days of account usage left and I would really like to backtest my system before going live.
Date Time Of Last Edit: 2017-06-06 16:50:02
[2017-06-06 17:19:20]
What is the exact symbol of the chart?
Make sure Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds is enabled.
Follow the instructions here to download and view more data:
http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData
If there still is a problem provide a copy of the Message Log by following these instructions:
