Date/Time: Sat, 26 Apr 2025 09:42:42 +0000
sc.BaseDateTimeIn question
View Count: 1294
[2017-06-03 02:09:50]
User103949 - Posts: 78
If I set the chart bar to be tick level, does sc.BaseDateTimeIn[sc.Index] contains millisecond for each tick?
[2017-06-03 21:57:18]
There are milliseconds, but the milliseconds just acts as a unique counter.
Here is information about accessing milliseconds:
ACSIL Programming Concepts: Accessing Milliseconds
Date Time Of Last Edit: 2017-06-05 20:32:13
[2017-06-04 16:24:44]
Merlin - Posts: 83
More on this, from Intraday Data File Format: s_IntradayRecord Structure Member Descriptions
"When writing tick by tick data to an Intraday data file, where each tick is a single record in the file, and multiple ticks/trades have the same timestamp, then it is acceptable for the Date-Time of the record to be the same timestamp as prior records. What Sierra Chart itself does in this case, is increment the millisecond portion of the Date-Time to create unique timestamps for each trade within a second."
Sierra has stated elsewhere that they do intend to start supporting real millisecond timestamps some time this year. Even 10ths of a second would be an improvement! But clearly it's a big project technically.
Merlin
[2017-06-05 20:33:27]
It is not a big project, it just requires numerous small changes in many places and tremendous attention to various details and it has to be done just right.
[2017-06-05 21:32:16]
Merlin - Posts: 83
Understood.
I've actually developed some indicator code that makes use of the current Sierra false-millisecond timestamps.
For example, by knowing the total # of trades that occur within a given second on a fast #-of-trades chart, I can synchronize an overlay market statistic chart with approximate sub-second accuracy.
Obviously this will be better with genuine millisecond values - but I will have some work to do on this code when your millisecond-accurate timestamps go live.
So it will be good to have some advance warning when this is coming!
Question: will you be rolling out millisecond-accurate timestamps on the Sierra market statistics at the same time?
Merlin
[2017-06-06 05:30:27]
thank you very much,merlin
