Date/Time: Tue, 14 Jan 2025 23:39:25 +0000
Windows error code 1455
View Count: 1939
[2017-06-01 20:02:47] |
@sstfrederik - Posts: 405 |
Hi, I have an error I have not seen before. Error was produced during the trading day. No interaction was done. It looks like the strategy stopped working. The following error loads 4 times in 2 seconds. Error loading Custom Studies DLL: C:\SierraChart-OPT\Data\sst_custom_strategy.dll. Windows error code 1455: The paging file is too small for this operation to complete. | 2017-06-01 11:36:23 * Any pointers? Thanks, Frederik Date Time Of Last Edit: 2017-06-01 20:07:30
[2017-06-01 20:10:32] |
You need to increase the operating system paging file size. Based on the error message, that should resolve the problem. For instructions how to do that, run an Internet search for "increasing windows paging file size". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
