Date/Time: Fri, 24 Jan 2025 08:27:59 +0000
NIFTY E-Mini
View Count: 1878
[2017-06-01 17:42:56] |
User39772 - Posts: 311 |
Hello, I have the following data feed: Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts. But do not find a way to load the following symbol: E-Mini Nifty 50. Can you help me ? |
[2017-06-02 04:53:35] |
Did you want to receive data for this futures market when connected to Interactive Brokers while using the Sierra Chart Exchange Data Feed? If so, do you have a link to the contract specifications for this on the Interactive Brokers website? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-02 13:10:06] |
Yes IB + SC Data Feed. Contract Spec: E-Mini S&P CNX Nifty Index Underlying MNCA Security Type IND Currency USD Exchange GLOBEX Symbol MNCA https://misc.interactivebrokers.com/cstools/contract_info/v3.9/index.php?action=Details&site=GEN&conid=77087829 |
[2017-06-06 05:55:27] |
The MNCA future symbol has been added. Restart Sierra Chart and you will see it in File >> Find Symbol >> Futures.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-06 05:55:44
[2019-01-16 01:21:21] |
User753841 - Posts: 1 |
HI, I JUST DOWNLOADED trial version of sierra chart and have interactive broker data feed but i am not able to open nifty futures as it is showing symbol not found |
[2019-01-16 08:18:28] |
On what exchange do you want the NIFTY futures?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-16 18:15:35
