Date/Time: Tue, 14 Jan 2025 23:41:27 +0000
Shortcut for Renko
View Count: 834
[2017-06-01 13:09:29]
Rino - Posts: 124
Is there a shortcut for Renko like there is for others.
Example: 5 tick Range is 5R of 5 Minutes is 5M, Etc
Thanks as always
[2017-06-01 17:29:23]
Refer to:
http://www.sierrachart.com/index.php?page=doc/ControlBar.php#CustomButtonsChartBarPeriod
[2017-06-01 17:55:12]
Rino - Posts: 124
Thanks,
That just gives you choice for "time".
I want it for bar type as well.
PS Like you can go to a range bar type with a R.
So 5 tick range bar is, 5 then R.
[2017-06-01 18:07:51]
We initially misunderstood. We gave you the documentation to set up custom Control Bar buttons for bar time periods which also supports Renko bars.
What you want is documented here:
Changing Chart Bars Period: Fast Changing by Keyboard
